1 - 3 of 3 Posts
Hi everyone so I was skimming though and just had a thought about the spark plugs when I end up getting all my bolt ons put on. Would it be beneficial to change them out when I put them on as I will be having an injector increase to 550cc or will the stock plugs be fine to run until it’s time to change them out? Any help would be great and if I’m in the wrong section can someone point me in the right direction thanks in advance.
Stock, heat range 7, plugs should be fine for bolt ons.
Your tuner can tell you if there is any pre-ignition prompting a colder plug.
1 - 3 of 3 Posts
