1 - 13 of 13 Posts
Hi guys,
I have a doubt related with the OEM Spark Plugs for Civic SI 2012
In the service mannual, Honda recommended:
NGK ILZKR7B11S
DENSO SXU22HCR11S
Wich is better or both are the same ?? This spark plug its of Iridium, for 100.000 KMs of use
2015 Honda Civic Si Coupe
Swapped over to NGK. Didn't know it had Denso until I pulled them out.
Thank's,.... I preffer continue with Denso.
Should be better than NGK...?? in a minimun perceptión... if it's possible to note a minimum perception
Either plug will do. I just prefer the NGK as I have always used them in all my Honda's.
But you can't go wrong.
Sent from my SM-N950W using Tapatalk
Had both factory part numbers. Both are equally good. Now i have some NGK Rutheniums from Rock auto and so far so good.
Marko!
1 - 13 of 13 Posts
