1 - 2 of 2 Posts
I started another thread detailing my install here, Install, but wanted to see if anyone had details on the speaker output wires from the head unit...
Obviously once I start my install I can trace the wires back from each factory speaker, but it would be much simpler to just wire up the re-Q 5 first and not have to worry about tracing all the wires. Thanks!!!
As far as I know the 9th gen Civic uses 08+ Honda Accord connector (not the 17-pin 06 Civic connector). It says so on crutchfield.com but you need to verify. Check on your tweeter, if your tweeter has a capacitor then the wire has full range signal (which is very likely if it's not Premium), and you can use that to connect to the DSP/amp. But that also means you have to drill holes through the molex going into the door.
1 - 2 of 2 Posts
