1 - 20 of 146 Posts
Ok guys does anyone on here know if any SPOON SPORTS brake kit is compatible with our cars(12'civic si non si 4 door or coupe) if so where can i pick this up and how much ?! Any info is greatly appreciated and Thank You in advance !:popcornbig:
Id like some info on the spoon kit, never heard of them lol
c'mon guys someone on here must know something on this topic ?!?!?!?!!?!?!?!?!?!?!?!?!?!:question:
best honda tuner in the world is #1 mugen #2 spoon, spoon sports k20a type-r motor are more popular than the original honda k20a motor. 60% of the racing team races honda buys spoon engine.
it's like your sneaker collector & you don't know the brand nike....
spoon s2000
$3,400.00 spoon coilover kit for FD2
spoon only sell the calipers, it's $1650 & there are several sizes, from what i know... the 8th gen civics uses tsx calipers & custom build their own kit.
average cost is around $2000 if you can run stock honda size rotors.
spoon calipers are very small & light weight, so you will not require a high disk rims for caliper clearance..
size comparison, stock tl type-s brembo vs spoon calipers..
Discussion Starter #9
just need to know what kit is close to applicable for the 12' model not what's fake real even though info is good knowledge to have kind of getting off topic though ....
Waste of money for very small upgrade if you would call it that they are made by the same company as the stock brakes on our Si's Nissin and are same pistons as ours.
your only 1/2 right, sw388 is made by desmond, but without spoon, this wheel will never be as popular as it is...
when rotas & drag copied these rims, they are trying to copy spoon sw388 not desmond regamaster
True but in retro spec the original spoon slip was just all flat black no label or anything,and they all do have there minor differences but yes just simply stating the manufacturer was Desmond and not spoon.but yes spoon did blow em up.
just because it's made by the same manufacturer, does not mean it's the same product.
spoon is the 1st company that develop smaller than average size 4 piston calipers for people wanna track their car with 16" wheels, this is by far the most superior design calipers in recent history, not only it can fit it with 16" wheels (most brembo style, 4 pot caliper require 17" or larger rims), it can also accept high off-set wheels (most brembo style, 4 pot caliper require high disk rims for caliper clearance) and it weight @ 5.73lbs (stock honda floating caliper average weight @ 10.36lbs)
waste money ? yes, if your civic is slow & does not require better deceleration.
Discussion Starter #19
Great information
1 - 20 of 146 Posts
