1 - 3 of 3 Posts
I know this topic has been discussed about and the final verdict seems to be do not use leds as they create a scattered beam pattern which can affect on coming drivers. (when used with the stock headlight housing)
However, I came across these leds.
9006 LED Headlight Kit | 9006 LED Fog Light Upgrade
I emailed them asking about this and their response was "LED bulbs are designed to give you the same pattern of light that you would get from the stock bulbs, "
Does anyone have any experience with these bulbs?
My biggest concern again is that these might be too bright and potentially dangerous for other drivers. They are rated at ~1750 lumens per bulb
I predict a future where LED are standard in vehicles. If you are preparing to upgrade, you should look at LED vs HID kits rather than LED vs Halogen bulbs. LEDs are more durable (no filament), have a longer lifespan, operate at a lower temperature, and are extremely efficient unlike halogen and HIDs.
I can't vouch for any experience with LED lights, but you should be the guinea pig and try them out. Return them if you are unhappy.
Did you try them?
1 - 3 of 3 Posts
