1 - 3 of 3 Posts
Here is a simple question for you guys, which I can't seem to figure out for the life of me. This clip is what holds the plastic floor trim piece. Any idea how to remove it? I tried prying it up, but was afraid i'd break it. This one is from the passenger side. uploadfromtaptalk1357060767652.jpg
Sent from my DROID4 using AutoGuide.Com Free App
It's just a serrated pin that attaches the panel to the structure underneath. They are usually very tight. You'll probably need a trim tool to slide under the lip of the fastener and then pry up gently to remove it.
Alright, thanks. I thought it might be something simple like that. I tried prying it up earlier, but it seemed pretty snug. Figured it'd be better to ask how to remove it as opposed to asking where to find a replacement for a broken one.
Also, anyone have any suggestions for this rubber boot that goes from the front door to the body? I can get the door side of this grommet off, but the body side seems to be clipped it. Should it just pry really hard at the plastic tabs?
Thanks guys!
1 - 3 of 3 Posts
