I am eager to see how this worked out for you. Get a chance to upload the pics yet?Its real easy man...i will try to put some pics up as soon as im done with final adjustments
Questions for you...
1. Did you replace the 8" with aftermarket sub using the original OEM HU? or
2. Did you hook up and amp, tap into speaker line with LOC and mount an aftermarket 8" sub into the back deck or
3. Did you use an enclosed sub and place it in the trunk?
4. Was your setup worth the time, effort and money?
If you can load them on your computer send them as attachments in a e-mail you can then save them and edit the pic in pic in paint. Click resize and chose pixels. Then put 700 in the top box and it will calculate the bottom box automatically then save and it should upload them with no problem. Hopefully this helps. LolI have pics but they are too bug to up load ( but the file is too big )
