1 - 20 of 28 Posts
· Registered
So I have a 2012 Honda Civic EX and the moonroof has stopped working. The sunroof is stuck tilted and the motor just clicks when I hit the switch to close or open the sunroof. Is there a way to manually close the sunroof until I get this fixed?
· Registered
I have a 12 Honda Civic Si. This problem started a month ago. Every time I open the sunroof (tilt or all the way) when I go to close it all it does is make a clicking noise and I have to do the reset procedure to get it to close again. The buttons work correctly when I open it, if I press tilt it tilts. If I press the auto-open it opens it just stops working when I try to close it.
The reset procedure works to get it closed again but the next time I open it and try to close it the same thing happens.
Is there a permanent fix for this problem?
Thanks!
· Registered
My sunroof only tilts now for some reason. It used to go back all the way. When I press the button to make it open fully it just makes a clicking sound. What could be the issue? Thanks
Edit: I've done the reset procedure to no avail and there are also no obstructions
· Registered
Thanks!
I have the same issue. Have you found the solution?
· Photoshop Masta
Search!
· Registered
Search!
This reset procedure did not work. I have already tried. Should've included that in the post
· Registered
i click the close button from tilt and it comes down but it almsot gets jammed and goes back up. i ahve to hold the sunroof with my hand out the door to close it. should i bring this to dealer or is there an easy solution?
· Registered
If it’s clicking, it’s not the motor. You either have a stuck track or bad lifter arm.
Lifter arms are somewhat easy to replace. If the track is damaged, you’re looking at a new sunroof sans glass.
I have a strange issue because if I let the car sit for 5+ hours, itll close again?? Very strange. Reset procedures do nothing. I dont have to touch it and it decides to just close later
1 - 20 of 28 Posts
