1 - 10 of 10 Posts
Would these kits be RBC compatible or would I need to use the stock manifold? I'm currently using the PRL adapter and bored injector RBC kit you sell.
What size injectors (dimensionally and flow rate 11/14mmx48/60mm) would be required for a low-boost stage 1 kit?
Just piecing things together on your website.
Thanks for your support, PRL.
we recommned the ID 1000's. you would want the standard 14mm x48mm injectors that the 2006-2011 SI uses. we have seals to make the injectors compatible with the bored out injector pockets we did for you in the RBC manifold.
As far as the RBC manifold, we have the piping kits compatible for it, won't be a problem at all for any RBC users out there
How about layaway with half down . Non refundable deposit?
Can you expand the discount on all items :)
PRL,
Shouldn't you also make an option for RBC to fit your turbo tube?
Most of the mod owners are already install RBC IM.
For February and March only!! Tax return season special on our 2012+ Civic Si stage 1&2 turbo kits. 15% off now!
Honda | Prl Motorsports
I priced out the kit about a week ago. Its the same price today?!?!
Is there a promo code to input?
sent from an artificial intelligence device that eats fruit for breakfast.
1 - 10 of 10 Posts
