1 - 17 of 17 Posts
2012 Honda Si HFP
2012 Civic Si HFP
RBC Manifold (Ported and Powder Coated)
RDX Injectors
Injector Dynamics 1000cc Injectors (uninstalled)
Skunk2 4” CAI
Skunk2 3” Alpha Downpipe (Catless)
Skunk2 Rad Cap
PLM Catless Header (uninstalled)
K-Tuned 3” Cat Back Exhaust
K-Tuned Fuel Rail
K-Tuned 72mm Throttle Body
K-Tuned K1 Coilovers
K-Tuned Control Arms (on route)
K-Tuned Camber Ball Joints
K-Tuned Fuel Pressure Gauge
K-Tuned Coil Pack Cover
K-Tuned High Flow Vented Valve Cover
K-Tuned Valve Cover Vent Filter
K-Tuned Oil Dip Stick
K-Tuned Oil Fill
K-Tuned Battery Tie Down
AEM Wideband AFR Gauge
AEM Water Temperature Gauge
AEM Meth Injection Kit (uninstalled)
Perrin Steering Wheel Gauge Pods
Hasport 70a Lower Torque Mount
Hasport 70a Upper Torque Mount
Tanabe Strut Bar
BWR Rear Subframe Brace
BWR Rear Lower Tie Bar
Progress 22” Rear Swaybar
Whiteline End Links
DC Lower Chassis Brace
DC Oil Baffle Filter
DC Timing Chain Cover
Neomotorsports Coilovers (rear)
5x9.5x17 Enkei RPF1 w P Zero Trofeo Rs
Acuity Short Shifter
Acuity Shifter Bushings
Acuity Coolant Lines
Acura TL Type S 4 Piston Brembo Calipers (not installed)
Stoptech Slotted Rotors and Race Pads
Sparco Evo 8852 Racing Bucket
APR 3D GT Wing (uninstalled)
K20 Built Head (uninstalled)
Skunk2 Stage 2 Race Cams
Skunk2 Rocker Arms
Supertech Inconel Exhaust Valves
Supertech Black Nitrate Intake Valves
Skunk2 Retainers
Skunk2 Valve Springs
ARP Head Studs
Manley Forged Pistons (for sale*)
Wiesco 87mm 10.2:1 CR Forged Pistons (ordered)
K1 Race Connecting Rods (ordered)
Bosch 65cc Fuel Pump (uninstalled)
CSF Radiator with Oil Cooler (uninstalled)
Exedy Stage3 Clutch w Lightweight Fly
Forged Designs Oil Catch W Vibrant AN Steel Braid
Buddy Club Carbon Fibre Steering Wheel
Mugen Master Cylinder Cover
AC Delete
Front Lip
Ventus Autoworks Front Splitter
Ventus Autoworks Side Splitters
Voltex Replica Rear Diffuser
Seibon Vented Carbon Fibre Hood
Amazon Carbon Fibre Canards
Sparco Tow Strap
JBL 8” Subwoofer
JL Audio SQ HIFI Sound System
Dynamat Sound Insulation
Pioneer Deck
Going big turbo next year with built head and forged Pistons. Wondering if anyone has some advice, tips, direction to offfer. Thinking of picking up a GTX3071 (or 76) Gen2 with the PRL kit.
Recently blown bottom end. New k24z7 here I come lol.
Ps. Not trying to be a douche with the huge parts lists with nonsense listed. It’s mostly for me to keep track of the build.
If your wanting to stay low key, such as not attracting police or may one day have children in your car, I recommend Borg Warners EFR. IWG, has the BOV built in. These are a bit more pricey, but they spool faster and install is easier.
2012 Honda Si HFP
Yeah I’m open to Borg and HKS as well. Kids won’t be an issue though. It’s going to be a dedicated track build.
Nice, when are you planning on installing the k20 head?
2012 Honda Si HFP
Discussion Starter · #14 ·
Daaaaaaaaaaaaang how's the fitment on the wheels/tires??
It’s good actually. Didn’t have to make any custom adjustments lol. Suspension is set a little low so it rubs in the rear. Gunna fix that over the winter.
2012 Honda Si HFP
Discussion Starter · #15 ·
So new update…
pretty sure I just blew the engine tonight so I’ll be looking for a k24z7 bottom end. All good, something fresher to put the new Pistons in. Now I can do rods, bearings, and maybe a crank if I’m feeling crazy.
So new update…
I'm considering new wheels and I do like the RPF1, but I don't like the bubble design on the ones that are less than 9inches wide.
And GL with your new engine!
2012 Honda Si HFP
Discussion Starter · #17 ·
Thanks buddy. And yeah you can’t go wrong with rfp1s really. Super light, good design, proven performance. I’m running a 17x9.5 with a 35 offset wrapped in 255 Trofeo Pzero
1 - 17 of 17 Posts
