hey all, thanks for having me here. I bought my 2015 Civic SE almost 10 years ago and have relatively kept up with routine maintenance as a first time car owner (oil changes, brake fluid changes, CVT fluid changes, tire rotations/alignments, air filter replacements etc).
I will admit I was a bit ignorant as I only changed my brake and CVT fluid twice. both fluids were changed around at the 5th year mark (2020) at 49,750 miles and the second time both again earlier this year at 94,000 miles in addition with the round CVT filter because of my lack of changing the CVT fluid in a timely manner.
my old independent Honda mechanic said both fluids looked good when he changed it the first time which led to me assuming that was how long both fluids lasted in the car. not excuses, just an explanation and now I know better. Interestingly enough, he didn't feel the need to change the factory front brake pads until at 70,000 miles so maybe it's my driving habits?
anyways- I just realized my little go-kart is about to hit 100,000 miles soon. I've been doing as much research as I can for the next couple of rounds of routine/preventative maintenance. I bought a few items from rockauto and various retailers in anticipation for the next maintenance minder notifications such as:
however as I'm doing research, I realized how little I know about my donkey. for example, I just learned about the PCV valve just an hour ago. I have never changed the PCV valve and nor has my old mechanic to my knowledge. this led me to wondering: what else am I missing?
I'll be picking up a PCV valve, a couple gallons of Honda coolant, a belt tensioner pivot bolt, windshield wiper blades, and maybe hondabond from my local Honda dealer.
Qs:
- 4x NGK spark plugs
- Bando serpentine belt
- Gates (rebranded Motorad) radiator cap
- Litens belt tensioner (rebranded INA but made in Slovakia instead of China)
- Liten idler pulley
- valve cover gasket
- Aisin thermostat
- Aisin water pump
- other small parts and tools like valve feeler gauges and such
Qs:
- should I even change my water pump? I only considered it because it's behind the belt tensioner and the pivot bolt looks like a pain to get past. but I'm seeing people leave their water pump for 200,000 miles and they're still fine
- are there any valves, gaskets, or any other critical parts I should replace/keep an eye on? I'm going to replace the valve gasket when I do the valve adjustment but I'm wondering if there are others that should also be replaced
- when i replace the PCV valve, should I also replace the hose?
- my rear passenger side wheel has been making this creaking noise whenever I drive off a driveway. doesn't happen every time but once in a while. I will admit that's the wheel that takes the most abuse as I sometimes take a turn too aggressively and the tire clips the curb or when I'm parallel parking, I might slowly back the tire into the curb. again, doesn't happen often but it does happen. the rim is still fine and somehow scratch-free. also, thank goodness for Firestone's lifetime alignment guarantee i bought in 2016.
- regarding #4: how do I know which bearings, rubber boot, suspension needs to be replaced just by looking at it?
