1 - 7 of 7 Posts
Hey guys so i've got a plan here
Bought this to start to use as a control button for the underseat lighting. We have three slots usable on the left of the steering wheel, only one is used for me :/
OEM Honda 02-04 Acura RSX DC5 Fog Light Switch Button Type S GENUINE PART NEW | eBay
So i'll but the above in and want to splice the wire from this unit i bought last week (below) and have it all connected so that its a series circuit and will be open/closed by this push button :)
NEW RED 4PC LED INTERIOR NEON UNDERSEAT DASH LIGHTS | eBay
Any suggestions??
Thanks in advance :)
Vanilla Ice is my hero!!!
Discussion Starter · #4 ·
No electricians?? :pout:
Ok so if anyone else wants to do this, this is what I'm gonna do. Worst case scenario my dad is gonna solder these connectors onto the HFP light system switch together and i will take pictures of everything i do and document it here as best as i can.
This is how i'm laying everything out just so you know.
As a side note, all the LED lighting are installed in 9" tubes. There are a total of 4 of them, with 18 LED's each.
Below is the layout:
Here's the math behind it. I figure the entire system requires about 1300mA. Each LED uses 18mA, with 18 LED in each tubing. We have 4 tubes of 18 LED's.
So.. 18mA x 18LED's = 324mA per tube
324mA x 4 tubes = 1296mA
Thank fully the operational range stated on the inverter into the tubes states a max range of 2500mA to as low as 1000mA on a 5v system.
Since the HFP lighting is run on 5v and a 3500mA inverter, i can take the secondary leads pushing 1500mA of current and use them on my LED system :D. That way the HFP lighting and the custom lighting is on the same 5 amp ACC fuse :D
Will post pick of my wonderful wiring and turn out once i get the chance to buy some more 18 gauge wire :D
Discussion Starter · #6 ·
**Sorry its such a miserable pic! tried to find overview schematics but there litterally don't exists!
Discussion Starter · #7 ·
1 - 7 of 7 Posts
