I finally corrected my paint.This was my first time trying this. I used a Porter Cable, and Jesstzn's suggestion of optimum compound, polish and duragloss 105.
Came out PERFECT! I bought all my supplies at Autogeek.com. The pads are all CCS smart pads, and are color coded.
I wanted to start a small section with the attitude of less first. So, I tried a white pad with just the Optimum polish. No swirls were removed. Then I tried a pink pad with the polish...better..but still swirls. Then I just went to the Optimum hyper compound with an orange pad. PERFECT. Great paint correction!
Then, I used the Optimum polish with a white pad, then the duragloss. With both the compound and the polish, I did six passes over an area. The whole project was 7 hours. Well worth the time and money spent.
Jesstin is correct that if you throw any wax over scratched paint...it is not going to come out good at all. You must do all your PREP before you apply waxes and polishes to get great results. I was using several waxes and polishes before I bought my Porter Cable and pads. Nothing worked before.
Now, I have white paint that is swirl free and shines shines shines. ! Once again Jesstzn, thank you! Great combo!
