1 - 5 of 5 Posts
Does anyone know if I bolt used identical rim from another Si on my Si will my tpms work okay? Does this require any reprogramming? Thank you.
What year is your si? Only 2012 and 2013 have direct wheel sensors. Those years require programming. Each sensor has a unique ID
Its a 2014 Si, the rim came off of a 2014/2015.
They yes, the tpms will work. 2014 is driven off the abs sensors so it doesn't matter which wheels you use.
1 - 5 of 5 Posts
