1 - 18 of 18 Posts
I don’t understand how this works. Also I cleaned my windshield with alcohol, vinegar, and Krud remover and this still happens. This isn’t after using wiper blades by the way. It’s just after getting in the car.
Water Atmosphere World Sky Building
you say above thats not after using the wipers... then what are we talking about here?
a coating on the glass?
maybe the windshield was treated with one of those trico or aquapel treatments and they missed a spot.
a spot? you mean like 80% of the entire windshield?
If alcohol, vinegar, and krud remover can't remove whatever this "treatment" is, what can?
The clay pads work well for removing hard water spots and existing hydrophobic coatings, but if the damage is deeper you may want to consider using a glass polishing compound with a regular non-DA polisher with a foam backed felt pad.
Discussion Starter · #10 ·
I'm thinking I'll give this a go and then maybe seal it with more Rain-X after.
Packaging and labeling Rectangle Material property Font Electric blue
Discussion Starter · #12 ·
That might work well but most professional detailers tend to use clay bars with a lubricant such as liquid glass cleaner or isopropyl alcohol to remove old hydrophobic coatings.
Ya I didn't want to wait for shipping so I did 70% iso wipe down then covered with rain-x. we'll see how it goes.
Another weird thing is that I was cleaning my wiper blade rubber with 70% iso and no matter how many passes I did, the towel would constantly get big dark spots all over it.
Discussion Starter · #15 ·
So this morning I couldn’t see anything out of my windshield and it was like it was permanently fogging. I think it might be this rain x turd. Going to have to remove it.
The 70% ISO you're using is partially breaking down the surface of the wipers... that's the only place that the "big dark spots" could come from.
I didn't see but have you ever clayed the windshield? Been having problems with mine and after clay barring no more problems.
Discussion Starter · #17 ·
Hi, thanks for the suggestion. Could you recommend a product?
That's a great idea.
After much research I purchased an excellent couple of products for prepping and then waxing the extraordinarily faded paint on my VW. The results are spectacular. I'm going to try the prepping solution and pad, and then the wax, on my windshield.
1 - 18 of 18 Posts
