I bought a R18A from a 2014 civic that I am putting in an off road rig and I am not sure what this part is on the bottom of the fuel rail. It looks like a pressure regulator but I cannot find it on any specs. It has a hole in the bottom of it.
I have never liked the 1/4 fuel inlet on the rail and wondered if this part on the bottom, which looks like it could screw off would be a place I could adapt a larger inlet tube.
I also do not see this device on most other 9th gen fuel rails so I am really curious.
Thanks.
Yep, looks like a damper to me. I have a 2013 and 2014 r18z1 fuel rail and they both do not have the damper. My wife has an HRV , but I have not checked to see what her fuel rail has.
I have not taken it apart. I would love to find a way to tap a larger line in to an R18 rail but i am not sure if this is viable......
I'm not sure that running a larger line to the stock rail would give you any increased flow.
How much power are you making? Are you running into fuel delivery problems?
--. The rail opening is like 0.22". It would be helpful to know verifiable data that shows how much fuel can pass a 0.22" (or 0.25) tube at say 60psi.
I've only heard opinions and not real verifiabe data. I know there can be many variables that affect things but hard data would be useful.
If anyone has links to data please share.
Thank you. Charlie
Sent from my SM-
