So I've been hearing this weird humming or ringing noise while going 35+ mph and it seems to be coming from the rear passenger side wheel well. I replaced wheel hub assembly with skf hub assembly. Didn't fix the problem. Then i rotated the tires... didn't fix the problem. So what I'm doing now is I ordered another skf rear hub assembly and two FW48 skf front wheel bearings. Getting them pressed in a few days after they arrive. If this doesn't work, what should my next approach be? Any advice would be wonderful. I was planning on investing in skunk2 coil overs but since this humming has cost me wheel bearing all around and i still have to pay for the wheel bearing to be pressed in, its going to be a little bit still :/
