1 - 4 of 4 Posts
Normally, the answer is NO, you cannot use wheels of a different bolt pattern.
That said, these wheels are dual drilled. 5x4.5 is the same as 5x114.3 so they will fit.
The width and offset are fine.
Can anyone tell me if these wheels will bolt up i wanna stay at 18 in wheels but wanna make these will fit before ordering. The factory wheels is 5x114 and these are 5x112 and its 18x8 and factory wheels is 18x 7.5
You got to check the hub diameter if you need to buy hub rings and most likely you will because wheel manufacturers might have the largest hub diameter to fit all makes. I used a 2005 mitsu eclipse rims, hub on wheels is larger, i bought plastic ones and it works well.
1 - 4 of 4 Posts
