1 - 13 of 13 Posts
I believe there is more discussion on this in another recent thread.
2016 is expected to be refreshed, yes.
Actually, the 2016s will be a whole new generation.
A 'refresh' is what happened to the sedans in 2013 and the coupes in 2014.
Glad we got that squared away. He's pretty much been confused for more than a year now.
Yeah, I know. Sometimes ya doesn't see a thread in a timely manner, ya know? hahaha
The Civic depends on the all-new Honda minimal worldwide platform.
It uses higher evaluation steel, the unit body is 68 lb (31 kg) lighter than the earlier model and the focal point of gravity has been diminished 0.6 in (15 mm). The car's wheelbase is 1.2 in (30 mm) longer with back plate brakes made standard. To limit NVH the Civic includes liquid filled suspension bushings. A double pinion guiding framework is presented alongside a thicker and progressively unbending 1.2 in (30 mm) distance across directing segment for improved controlling feel; moreover, the directing rigging proportion is variable, with 2.2 goes lock-to-bolt contrasted with 3.1 diverts lock-to-bolt from the past model and a speedier 10.93:1 controlling proportion.
The Civic relies upon the all-new Honda insignificant overall stage.
It utilizes higher assessment steel, the unit body is 68 lb (31 kg) lighter than the previous model and the point of convergence of gravity has been reduced 0.6 in (15 mm). The vehicle's wheelbase is 1.2 in (30 mm) longer with back plate brakes made standard. To confine NVH the Civic car incorporates fluid filled suspension bushings. A twofold pinion managing system is exhibited close by a thicker and continuously inflexible 1.2 in (30 mm) separation crosswise over coordinating section for improved controlling feel; in addition, the coordinating apparatus extent is variable, with 2.2 goes lock-to-jolt appeared differently in relation to 3.1 redirects lock-to-dart from the past model and a speedier 10.93:1 controlling extent.
David, what?
1 - 13 of 13 Posts
