Maybe OP is trying to install the FKX tower brace:biglaugh:. I'm thinking of getting that, hopefully I don't have any problems removing the wiper arms lol.the arm??? Why are you trying to remove the arm? if you are just replacing the wiper, you don't need to remove the arm.
Once you have the bolt off, either push on the joint of the arm or pull the arm up and wiggle the joint to loosen the entire arm.I hate to dig up an old thread, but i cant figure out how to remove the wiper arm. took the bolt off and i cant seem to remove the arm. Im trying to install the tower brace...
This is right on. After trying to pull the arm off and failing, I found that I had to PUSH firmly on the area of the arm right by the bolt. Totally counterintuitive, but I felt something give and the arm came right off.Once you have the bolt off, either push on the joint of the arm or pull the arm up and wiggle the joint to loosen the entire arm.
Thanks for the tip I'll be installing mine soon. :thumb:Once you have the bolt off, either push on the joint of the arm or pull the arm up and wiggle the joint to loosen the entire arm.
Thanks for the tip I will mark off the wiper location with tape before I remove the wipers to install the strut tower bar.Ya we had a real hard time taking my wipers off to install the Megan tower brace. Luckily my windshield was dirty so that we could see where to line up the wipers when reinstalling!
