Just purchased part 25430-PLR-003 (Transmission Filter) from Amazon (auto trans). Have you ever replaced it? Is it important to replace it?
Your trans filter is actually a pan and not an in line filter
I was wondering the same a while back... my AT trans shutters/vibrates around 1500-1800 rpm specifically on the shift from 2nd to 3rd when not appling much throttle.. hiy it hard and it shifts normal.
Was told be several on this and another board to change the trans fluid 3 times.
I looked into a filter and found there is a filter, Honda dealer said its a lifetime filter and did not normally get changed on a fluid change.
Further search I did find a YT video showing where the filter is and how to change it, but it was for an 8th gen.
Yes it's important. So yes it needs to be changed every 30-50kJust purchased part 25430-PLR-003 (Transmission Filter) from Amazon (auto trans). Have you ever replaced it? Is it important to replace it?
But the darned thing might as well be inside the transmission, because it's real pain to get at it... it is just an in line filter. lol
Thanks, many thanks. If they were driving economy cars built in the 1970's, I'm positive they would not have fared as well.I'm glad your kids are safe!
@scottyrocks , these videos are definitely revealing; thanks for posting. 9th Gen Civics really do a good job here as far as protecting driver and passengers. Makes me feel better about choosing these vehicles when helping my kids "get into owning a set of wheels."9th gen Civics did very well in passenger safety in NHTSA crash tests.
Yup. S-K, like Proto, Armstrong and UTICA, you can still find perfect examples in new shape on eBay, all for far less cost than anything else out there.damn really you went old school with SK
Are you for real? They're totally in budget if you know how to look and win on eBay, and it doesn't require a whole lot of time or moxie to do that. It's almost impossible to counterfeit these old school high-quality tool items, too. My "labeled as used" S-K torque wrenches arrived in new-from-the-factory packaging.Specialty pliers aren't in everyone's budget that drives a civic.
Have yet to open one up from a Civic, but I've opened up the spin-on version of this filter that sat on two different Odysseys (a pair of 5-speeds.) I compared the pleated filter elements I removed "post mortem" to images of a dissected Civic filter posted by a Civic owner. The pleated element is almost identical in shape and construction down to the bypass valve, just sits in a different can for the Gen 2 Odyssey 3-shaft 5-speed A/T.Have you opened one up? I wonder how much debris is in it.
Super correct. I'll have to re-check my e-copy of the 9th Gen Helm manual, but these Hondamatic-styled A/T's share common hard architecture. I'mI feel like the clutch debris gets picked up by the trans magnet before it even gets a chance to go into the filter.
Yes,but you, yourself,know what to look for... Chances are if you're on a forum asking for stuff 7/10 times you're not aware of certain specialty pliers.Yup. S-K, like Proto, Armstrong and UTICA, you can still find perfect examples in new shape on eBay, all for far less cost than anything else out there.
One of my rollaways is filled with this stuff, all purchased on-the-cheap, piecemeal.
BTW, you can be 650 lbs. and still get the job done with these specialty pliers, LOL ... they use a remote cable-actuated trigger to close the jaws, which means you just place it on the clamp with one hand, set, and squeeze the remote handgrip, then slide the constant tension clamp off from where it sits. Man, I love 5h1t that makes life tons easier.
Like the guy who dissected the Civic filter for us (I saved the images for reference), I basically found a thin, thin, thin layer of black toothpaste. Based on the flow path in the Helm manual for these Honda transmissions, the magnetic plug "sees" the ATF first, and then the sump filter gets next dibs on capturing contaminants. There are three fluid circuits after that (heat exchanger/cooler w filter [if no heat exchange fluid circuit, then filter only], fluid power circuits to linear solenoid-activated valves, and TC with TCC PR valving).
Super correct. I'll have to re-check my e-copy of the 9th Gen Helm manual, but these Hondamatic-styled A/T's share common hard architecture. I'm99.9%100% sure that this is correct. Magnet on plug gets first chance to capture contaminants, sump filter in transmission captures contaminants, in-line filter on top sits in one of the three remaining fluid pathways after the ATF pump ... in short, that little in-line filter is "last in line" and gets possibly only about 1/3 of the total fluid volume after the ATF pump.
OF
