101 - 107 of 107 Posts
I'm almost at 15K too. Debating if it's really necessary right now or if I should wait until the maintenance minder tells me to.
If you've been slacking on going to the gym, you'll get a pretty decent arm workout as the shifter continues to get notchier and notchier if you wait for the MM, so it's not a totally bad idea to wait eons for the MM lol
This explains a lot. Gosh, I hate tennis elbow.
This was really easy. I didn't expect it to be hard, but it was a lot cleaner than it was when I had an integra.
17 mm socket and wrench (3/8" driver preferred)
6" long extension and knuckle adapter.
I had 2' of 5/8" clear tube and it was too long, I would do 1' long at 1/2" diameter instead.
Funnel that fits into tube.
Oil catch
2-3qt Honda MTF (I used 2.5qts)
I cut a slit in the end of the 5/8" diameter hose about 2 inches, that is going into the filler hole of the transmission as the tube is too big in diameter.
I was able to put the rear wheels on ramps, put the front on jack stands and do everything sitting in the driver-side tire well. Once the tire is removed you will see the axle going into the transmission. There are two bolt heads that are noticeable facing you.
1. unscrew 3/8" head bolt -Drain bolt.
2. Unscrew filler bolt with 3/8" ratchet, extension, 17mm socket, and knuckle.
3. Insert drain plug when oil stops coming out.
4. Fill oil through funnel and clear tube.
5. Put Filler bolt back in. approx 30 ft/lb
Good job, now you can put the wheel back on and enjoy a smooth shifting transmission.
College Hills Torque Specs:
Manual Transmission Drain Plug: 29 lb*ft
Manual Transmission Fill Plug: 32 lb*ft
Looks like I get to do this again. I just hit 60k on my odometer and got the B1 notification (oil change/tire rotation)
Stigmacher, if you had popped open the fill bolt on top of the transmission, could you have just opened the drain bolt, and not had to mess with getting a new crush washer on the check bolt? Maybe save yourself some trouble?
Thanks for the video, btw.
I use the side plugs on the transmission to drain/refill and the honda dealership sold me a 14mm and 20mm crush washer.
This is at 20K miles. Shifts great and smooth. Pretty normal for manual trans
in my experience as a technician. But 2 quarts of Honda MTF is cheap enough.
Do it at 15K
Hey all,
Just bought a 2012 SI and pick it up tomorrow. Sold my 2008 SI 8th gen yesterday. I always used GM Synchromesh on that tranny since 8K miles on it. Changed the fluid every 30K miles.
When I sold the car it had over 115K miles and the tranny still shifted amazing. Almost like new. Didn't even suffer the infamous 2nd/3rd gear grind.
Anyone else using GM Synchromesh fluid?
