Noise when accelerating at an incline in 1st gear
2 reading
1.4K views 22 replies 11 participants last post by  14Fb6
#1 ·
Hey everyone,
I have this 2015 Honda Civic SI Coupe and I have had this consistent noise that only comes with coming off the clutch at an incline with acceleration. The car shifts and the clutch performs fine otherwise when driving. I’m currently at 89xxx miles with the stock OEM clutch. Could anybody have an idea of what could be the cause of this? Any help would be appreciated.
#2 ·
Is the clutch slipping? Is the engine revving and the car is not moving as quickly as it sounds like it should be moving?
#5 ·
Hey guys, thank you for the quick replies. I’ve actually seen a post in particular stating that this seems to be a common issue for the 9th gen civics. A user in particular stated that their throw out and pilot bearing needed to be replaced and the noise seems to subside. There’s also a video showing a similar noise I was experiencing towards the bottom of the page. I’ll post the link to that discussion here. I’ll still take it to the mechanic soon to have it inspected. Thanks you guys for your help!
#10 ·
Thank you guys for all of the updates. I will get this addressed soon. While the transmission is being worked on, I was thinking about potentially upgrading the clutch too. What clutch do you guys recommended? I have an exhaust, HPS coupler, and tune. I don’t plan on doing anything else to it at the moment. I was thinking an exedy clutch kit since it’s pretty close to OEM but I cannot find a kit that includes a flywheel too. Action clutch and clutch master is also an option I’ve been looking at.
#21 ·
If it sounds like a groan, it's a loose or bowing spring on the clutch plate.
My '12 Si does it with 135k miles on it. More of an irritation to me, I don't think replacing the clutch is necessary until it's failing.
I drive pretty hard very often and it doesn't affect performance.
