I'd like to replace the stock wipers with rain-x latitudes, but I can't find any information on sizing -- anyone know what size blades the 2012 EX takes?
great info JAKE, thanks buddyBy the way just in case anyone is wondering since I didn't see it posted here the Sedan and Coupe have different wiper blade sizes.
The Sedan has a 26" Driver's side and 22" Passenger side, while the Coupe has a 28" Driver's side and 24" Passenger side.
Thanks so much for the fast response!#8 and #11 are the full blades, which is what you need.
might as well order some refills too - #9 and #10
your passenger side refill is 35 cents cheaper than mine ... no fair
According to the book at Auto Zone and the Trico web site, a 2012 Civic sedan uses a 26" blade for the driver's side and a 22" blade for the passenger side. The 2012 coupe uses a 28" blade for the driver's side and a 24" blade for the passenger side.I believe they are 22 and 26. If you have some tape measure just measure them. That should confirm the sizes.
That housing part of the blades. You should be able to lift up a small tab at the hinge point and then slide the factory blade out. It's a standard J-hook mount.So I've had the Civic Ex for about a month now and I want to replace the stock wiper blades. Normally this isn't a problem for me but I looked at ours and there seems to be some sort of housing thing at encases the actual blade--quite different than any other car I've had before.
What casing are you thinking of? If you mean the aerodynamic housing, I think they're a built-in part of the factory blade. I don't think you can remove it.I'm planning on changing wiper blades, should I get rid of the OEM casing?
That sounds like a pretty nasty engineering challenge. I think it would be easier to just design an extra hot blower at the base of the window to keep the glass temperature above freezing. My wife's minivan (a Kia Sedona) has a "front de-icer" button that I think is designed for just that purpose.... if the blades, themselves, are heated, ice will not form on them, and they can do their job (maybe).
How do you run wires through wiper blades to heat them?
Yep!OEM wiper inserts for me, they work FANTASTIC! $15 and they last a year.
. . . or two with Rain-x.OEM wiper inserts for me, they work FANTASTIC! $15 and they last a year.
If rain-x is more than $15, I break even! :icon_wave:. . . or two with Rain-x.
