301 - 320 of 550 Posts
I ordered my camera too, this is easy now, any members in the inland empire I don't mind helping you out with this once I get mine in the mail
I'm fairly new to Honda, but what other generation/honda model pins can I use, can I just pop on over to the junkyard and find some pins, From say a ecu harness?
I feel ya on that, and what were you thinking With the RCA video wire, just cutting the connection off and wiring it into the pins? 0r getting a female RCA end and wire that into the imid harness to plug the camera into?
I hope that either of those options will work.
By the way, I found two options to avoid running a coax from the back of the car to the iMID:
I purchased and tested this wireless setup.
Or if you want a wired setup, you can use a Cat5 cable and a pair of video baluns.
I have all the parts; the only thing holding me back from completing the project is my reluctance to disassemble the dash of a car with less than 2,000 miles.
Where were you going to draw the reverse signal from?
ok ive pinned connectors before
but you guys are making this super confusing.
so i understand you need,
1.Backup cam
2.Wireless transponder thing
3. Pins
then what
what pins do i buy,
and how do i connect this?
it sounds super simple.
do i add pins to the connector?
where do i wire the wires.
i read the whole thread and only kinda get it.
what are the main connectors pins involved, where do i add the new pins and wires, what connects to what.
someone draw me a ghetto diagram
