141 - 150 of 150 Posts
coilover recommendation
Hello everyone,
finally dropping my 2013 Honda civic 2dr Ex. asking for recommendation for coilovers. i was thinking of getting Tein of Function form. Which one do you think is better? car will be used for daily drive.
Hello everyone,
Merged, with expiring redirect, into stickied which coilovers? thread.
Hello everyone,
If you get tein youd have to get their conversion kit to run them on non si versions its like 150 and the street basis z are 500 so in total 650 give or take. The function and form you dont have to worry about that but even still they are at least 150 more.
Any springs for a 2014 civic sedan lx that only drop 1.2 inches or less? (excluding any hfp suspension)
I have a steep driveway and road conditions are bad so im looking for the smallest drop possible. Again, for my LX.
Thanks!
Coilover choices?
So I’ve been looking around for coils and tbh I’m not sure what to choose I’m just looking for something that’ll take some of the wheel gap away but also be DDable. I’ve read in one of the post on here that swift springs is a upgrade to any coilover setup, or am I understanding that incorrectly? Also I understand I would need to pick up some Skunk2 rear camber arms and possibly some front camber bolts as well? Any help would be greatly appreciated.
I went with the Tein Flex Z. They are soft and DDable.
If you go with Swift spring, I would want to replace the damper at the same time. Your car probably has a lot of miles and are on the original damper.
Depending on how low and what camber you want, will determine what you will need.
The Flex Z comes with front camber plates and can be pair with camber bolts.
The rear suspension on our car are non-adjustable. I would suggest Dorman 521-872 Rear Upper Suspension Control Arm.
I’m not wanting to go to low just yet but to where I can slam the car when I want to. I saw BC racing BR are good coils to go with but then again I’m not sure tbh, I saw that function and form type 2s are decent for the price as well.
Well these threads seem pretty dead but I’ll try anyway.
Looking to revamp suspension on a 13’ si sedan. Looking at Five8 Industries SS coilovers, eibach RSB, leaving FSB stock for now and upgrading all end links to moog (or other suggestions?)
She’s a DD, just want to tighten her up a bit and start working on little things. Any major suggestions? Anyone have experience with Five8?
I've got a 2014 ex sedan that I already upgraded the rear sway bar. It helped a ton but the car is going into the shop for hail damage and some other normal maintenance. I'm thinking of taking the opportunity to replace the suspension...but I'm not sure what to get. It's got to be gf friendly.
I used to have a GTI which had the perfect balance between comfort and handling. So I'm shooting for something like that. I was previously leaning towards just upgrading the struts and leaving the stock springs on but I'm not sure that would even make a difference?
