21 - 40 of 41 Posts
Okay, so what is incorrect about the following information? If people reply to this thread or PM me about it I'll update the original post. Also, double-check bulb sizes with your Owner's Manual, the bulb itself bulb socket, and/or http://www.sylvania.com/en-us/applications/automotive-lighting-systems/Pages/lrgmain.aspx and don't blame this thread for your lack of researching.
So.... I couldn't find this or the information was so scattered when I searched. Here is what I came up with from taking my bulbs out/searching/reading my owner's manual.
2014 Honda Civic Coupe/Sedan Bulb List:
Exterior
High Beam: HB3/9005 60W
Low Beam: HB4/9006 51W
Fog Lights
Non-Si: H11 55W
Si: H8 35W
Front Turn Signal/Parking/Side Marker: 7443 T20 28/8 W Amber
Brake/Taillight: 21/5W
Rear Turn Signal Light: 992/7440A 21W Amber
Rear Side Marker Light: LED
Back-up/Reverse Light: 921 16 W
Tailights: 7443 T20 3 CP
Rear License Plate: 194/168 T10 5W
High-Mount Brake Light
Non-Si: 7440 21 W
Si: LED
Interior
Map Light: 194/168 T10 5W
Dome Light: 194/168 T10 8W
Trunk/Cargo Area: 194/168 T10 5W
It should apply to the 2013+ civic coupe also. I believe the only differing factor is the fog lights for the SI and non si civics (can somebody confirm?).
Fog Light Coupe
Non-Si: H11 55w
Si: H11 55W
Fog Light Sedan
Non-Si: H11 55w
Si: H8 35w
I will say TRS and Amazon both recommend H11 Fog bulbs.
For both the coupes and sedans? Kev says they differ:
Coupes fogs are h11 sedan fogs are h8.
Then to address this:
I think H8 and H11 are both similar?
team3d chimed in:
honda oval fog lights usually are h11, honda round fog lights usually are h8
both h11 & h8 are the exact same bulb, the difference is h11 is 55w, h8 is 35w
but can someone not quoted already in this post (this excludes kev, ericc, and team3d) confirm that?
I have a set of H11 HID bulbs that I used for a long time in my 13 Si Sedan. They worked fine, but after messing with them today, they definitely feel a tad loose. I may pick up a pair of H8s to test.
Another issue is this:
H11B Morimoto XB HID Bulbs - Xenon Headlight Bulbs - The Retrofit Source
H11B/H9/H8 are grouped together. So I honestly have no clue. The one thing I do know is H11 bulbs are slightly loose in a 2013+ Sedan.
INFORMATION FROM SYLVANIA.COM (for bulb sizes) AND https://en.wikipedia.org/wiki/List_of_automotive_light_bulb_types (for bulb type similarities)
2014 LX, EX, and EX-L coupe:
Reverse: 921 (AKA W16W, WY16W)
High beams/DRLs: 9005 (AKA HB3, HB3A)
Dome light: 175
License plate light: 168 (AKA W5W)
Map light: 175
Trunk/cargo light: 168 (AKA W5W)
Third brake light: ????
Brake light: ????
Rear turn signal: 7440 (AKA W21W, WY21W)
Front turn signal: 7443 (AKA W21/5W)
Fog lights (if equipped): ????
2014 LX, EX, and EX-L sedan:
Dome light: 175
Map light: 175
Brake light: ????
Rear turn signal: 7440A (AKA W21W, WY21W)
Front turn signal: 7444NA
2014 Hybrid and Hybrid-L sedan:
High beams: 9005 (AKA HB3, HB3A)
DRLs: LED
Dome light: 175
Map light: 175
Brake light: ????
2014 Si coupe:
Dome light: 175
Map light: 175
Third brake light: LED?
Brake light: ????
Fog lights: ????
2014 Si sedan:
Dome light: 175
Map light: 175
Brake light: ????
Fog lights: ????
2015 non-specific Civic model:
Brake light: 7443 (AKA W21/5W)
Third brake light (model-specific): LED or 7440
Dome light: 175
Low beam (model-specific): H11 or 9006
Map light: 175
Front turn signal (model-specific): 7444NA or 7443 or LED or 168
Brake/tail light: 7443 (outer, AKA W21/5W) or 168 (inner, AKA W5W)
Fog lights: H11
If you can verify any of the above information or add information that I don't know (as indicated by the question marks) or if I'm missing a bulb or two please post it in this thread or PM me.
What bulbs do I get?
Please recommend brands and what specific type of bulbs I need to replace the interior bulbs to LED's (map, dome), along with license plate, fogs, low and high beams.
I have a 2015 SI coupe.
Sorry if this was already posted, couldn't find a thread for it.
Thank you!
Okay, so what is incorrect about the following information? If people reply to this thread or PM me about it I'll update the original post. Also, double-check bulb sizes with your Owner's Manual, the bulb itself bulb socket, and/or Lamp Replacement Guide Home and don't blame this thread for your lack of researching.
Checking your owners manual is like inserting a disk into a blue ray player. Not happening.
/now have a spare 9006/HB4 for the Subaru
//off to get a H11
op is super helpful. Thanks!
Exterior
Fog Lights 1.8 L Model: H11 55W
Fog Lights 2.4 L Model (SI): H8 35W
Brake/Taillight: 21/5 W
Rear Turn Signal Light: 992/7440A 21 W Amber
High-Mount Brake Light 1.8 L Model: 7440 21 W
High-Mount Brake Light 2.4 L Model (SI): LED
Interior
Fog Light Coupe
Non SI= H11 55w
SI= H11 55W
Fog Light Sedan
Non SI= H11 55w
SI= H8 35w
****if anything is inaccurate PLEASE LET ME KNOW****
Hope this helps!:thumb:
Edit by DWils: this information is currently up for debate and is in the process of being corrected. Please be patient and read through the entire thread before basing your purchasing decision on this information.
Thanks for the listing. Replaced my hi/lo headlights already with new Philips Ultras but thinking about changing over to LEDs after the winter breaks - most of my driving's done at night.
Actually... after further research, as the OEM lenses and reflector housings weren't designed for LEDs (as regards to the exact placement of the LED light source with respect to the reflectors versus the placement of traditional-style incandescent bulbs - no matter the manufacturer) I've given up on the idea of replacing traditional halogen lamps with LEDs. For LEDs to be truly effective and efficient, the whole reflector housing would have to be re-designed.
21 - 40 of 41 Posts
