DIY: Door Panel Removal on LX Sedan
1 reading
26K views 14 replies 10 participants last post by  AKzxr
#1 · (Edited)
DIY: Door Panel Removal on DX/LX/EX Sedan
Didn't see any guides for an non-si door removal. Hope this will help for anyone who needs to do this! Step 1. Release the locking tab and pull out the plastic piece inside the door handle. Remove the screw underneath.
2. Pry the entire switch panel out (there is an indent on the very front)
Underside of black plastic piece
3. Release 2 wire clips from the switch panel
4. Remove 2nd screw 5. Pry the door panel off. The entire panel is held on by green push clips and hooked in at the top, so pry starting from the bottom. !! BE CAREFUL !! the door handle and wires will still be attatched to the inside of the panel. Release it by pushing the top 2 clips on the inside.
Door lock wires, the 2 large yellow and blue wires are door lock/unlock. If you're installing the KP Technologies electronic beep module.
