18x8.5 +45 offset, 225/40/18 tires H&R 1.5" drop
would this set up work on my si coupe?
Thank you for your input.You need to specify what tire you plan on running. Each tire company and model have different tread width.
For example, Toyo Proxy R888's trend width is 8.8", while Kumho ECSTA V720 trend width 8.6". Both of these tires are 245/40R17.
Here are some example fitment.
The more narrow width changes the discussion entirely. The main concern with a 9" +45 is possible rubbing of the strut hence Civi9 using a spacer.I've got I believe the same wheel size as you, except 8 in wide rim. I'm running 245/45/17. No rubbing yet, but there's no way I could lower car.
Nice! I bought 3mm spacers as well. As for my drop, I don't think I'll be "slammed" since my driveway isn't flat. Thank you! Should post pics soon of my setup.OP, I have 17x9 +45mm RPF1's with 245/40-17 tires. I'm dropped to about a finger width at each corner. I only get very mild rubbing of the wheel-well liner on big dips in the road. It broke off a clip inside each wheel well, but nothing else. I have my front Camber set almost completely to 0. I need to reset to maybe -0.5 r -1, and the rubbing will disappear. I track my car, so that would help with traction as well.
I have 3mm spacers up front as well.
Thank you guys, hopefully, if weather permits, I should have my BC coils and wheels installed.The more narrow width changes the discussion entirely. The main concern with a 9" +45 is possible rubbing of the strut hence Civi9 using a spacer.
I was about to ask the same thing. I've got a leaking shock, and as much as I like the stock set-up, I'm curious what my options are as I don't want my car lowered (or not much).I don't think I've really seen this addressed (or maybe it's a non-issue on the 9th gens), but what is everyone doing with their fender liner once the fenders are rolled?
I'm thinking with the setup that I want to eventually get I'll have to roll the fenders, but I don't want to delete the liner or have it just flapping around. I want to retain the liner, but not have it look janky.
This could actually be its own thread, as it is unique sub-topic of fender rolling. Let's see what happens here, and I could create a thread and move the relevant posts over there.I don't think I've really seen this addressed (or maybe it's a non-issue on the 9th gens), but what is everyone doing with their fender liner once the fenders are rolled?
What car is this for? The aspect ratio is relative to width and diameter.planning on keeping my daily stock height and looking at 10th gen si wheels.
do you guys think I could get away with a 50 tire or is that just asking for trouble?
and if so and I end up going with a 9th gen si, could I get away with a 55 tire?
Oh I thought it was only relative to diameter. But yeah on stock 18s. You don't think you could have gotten away with 55 on the 17s?What car is this for? The aspect ratio is relative to width and diameter.planning on keeping my daily stock height and looking at 10th gen si wheels.
If you are referring to stock 18s, 50 series would be way big.
On 17s, i ran 205/50 in the winter and they worked well.
You probably will need a fender roll.Soon lowering my 2014 si sedan on megan racing lowering springs, looking to buy rims as well. Probabaly some Enkei ts6 or some other work te37 reps. I was hoping to be able to fit 18x8.5 +35 for a nice flush fit, do I have to roll fender or should I be fine?
